Will a Wolfsburg Steering Wheel fit a 1992 Cabriolet??
(In Topic #132121)
Hi
I'd like to fit a Wolfsburg Steering Wheel to my 1992 Cabriolet but am not sure if it will fit.
I've been told that my car has a large spline fitted but would need a small spline to be able to fit the wheel. Is this true? Can the large spline be removed? And if so is it easy to do??
Any help is greatly appreciated.
Tim
Tim
It will fit but only after you've removed the extra collar that VW fitted on the column of the later cars. Not an easy task without the right tool but I believe VW dealers would be able to help.
DubPartz
Thats good news as ive just bought one from AL_MK1 and just sent him a pm to see if that would work as a solution and then i see this post !!
And yeah those collars are a real pain to get off !!!!!!!!
But at least now i know it will fit !!
Dave
Dave
Hi DubPartz
Thanks for that.
I'm assuming that's the expensive option? Anyone know of a cheaper option?
Also does anyone know of an alternative steering wheel that will fit? I'd like one similar in style to the Wolfsburg if possible.
Tim
Thanks for that.
Tim
It shouldnt be that expensive i did have one of those tools to take the collar off think i got it from halfords or some where like that its just really annoying trying to get it lined up right because if you dont it just pings off every time you start to get pressure on the collar although that might have just been the tool i had as it was pretty cheap !! ill be haveing a go in the next week or so as i really want the wheel i bought to fit and think it will look sweet if it does ill post back when ive done let you know what tool i got and where etc if ya like !!
Dave
Dave
Bucko said
Hi DubPartz
Thanks for that.
Tim
I've never had it done myself but would employ a bit of charm, approach them and hope they would do it FOC. Maybe you have some local vw specialists nearby who could do you a favour and gain work in future ??
DubPartz
Dave
I'd be very grateful if you could let me know how you get on. Also what tool you used to remove the spline.
Tim
Tim
well done mine this afternoon !! i went and got a pulley gear from halfords £26 cheap and not great to be honest after todays experiance im sure there would be better versions out there !!
Any way i had to remove the old wheel and the indicator and wiper stalks all very simple like i say that tool wasnt great it did help but also had to be very steady with a hack saw and file to get the tool to grip the back of the collar still wouldnt do it ! kept spraying some wd to hopefully make it slide off easier then resorted to heating it up and brought out the very technical tools of hammer and chisel gave it some good taps from behind the collar and it started to come wasnt easy as the dash is obviously in the way! then went back to the pully gear and eventually it popped off !!!!
The wolfsburg wheel then fits straight on !!!! and looks sweet as …….
To be honest it takes alot patience and alot of effin and jeffin and i nearly gave up but got there in the end and now im well chuffed !!
My car is sorn so couldnt take it to a garage but might be worth getting a price from them if ya dont fancy it yourself but i knew id done this on a previous cabby so was happy to take it on ! its not really technical its just so annoying !! lol
But at least you get the wheel you really want and it does fit !!!!!! if you want to know any more give me shout !
Dave
Dave
Just to add i had to be extreamly careful with the hack saw and file last thing you want to do is damage the main steering column underneath and try to tape over the steering bearing if you have to do the same saves all the fileings etc getting into the bearing!
Dave
Dave
This has given me some inspiration.
I have been attempting this challenge removing the spline adaptor and its so stubborn. Even used a hand made gear puller but no budging including heat and swearing lol.
Gonna remove the stalks to let the fox see the rabbit and maybe I might be in luck.
Good luck mate having read the thread it sounds like there's a fair bit of ballache involved.
