wheel arch repair
(In Topic #75232)
wheel arch repair
im determined to keep my mars red 1982 car on the road,
is this a rectifiable problem, any good parts/cost tips ?
1981 mars red gti
2001 new beetle
1990 clipper
1981 1500 gls
2001 new beetle
1990 clipper
1981 1500 gls
Hadrian (Perfect panels) from your local "Brown Brothers" have some repair panels for inner & outer rear wheel arches…..GSF carry some
http://www.perfectpanels.co.uk/index_catalogues.htm
and just spotted this…..
http://cgi.ebay.co.uk/New-vw-mk1-golf-rear-inner-wheel-arch-rare_W0QQitemZ4581474886QQcategoryZ9889QQrdZ1QQcmdZViewItem
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
there's quiet a few of us here that have replaced arches so if you get stuck just ask :wink:
1983 1100 C
1983 1100 C
My old rusted arch ready to be cut out.
If your replacing the inner arch as well, cut the outer skin futher up, leaving about 10mm ish of the inner sticking out, so you can lap joint the new inner on the bottom of the old remaining inner arch, then i spot welded it on.
Then i clamped the outer on, to make sure it was siting right and tacked it on until i got it right.
Then i spotted the outer on, being careful not to let too much heat build up, i used a damp old sponge, to cool down the welds, and also when building the spots up, dont weld up all one side, spread the welds to different parts of the repair, so as not to make it bow out.
Then i ground the welds down, and fillered away, gaining sum blisters :roll:
Hope this helps, you just gotta get stuck in, then you can say you did it! :wink:
1983 1100 C
1983 1100 C
