water water
(In Topic #106389)
water water
my mate has a black 1.6 gti,and he keeps on getting water in the footwells
any ideas?
1983 black gti ELD380Y
Is it a sunroof model?
Could be getting in from behind the dash too… I beleive it's where some corrossion likes to manifest itself… can't remember where exactly someone said it comes in though… failing that check all seals… sunroof seal.. door seals etc and see if any are perished :dontknow:
water water
its not got a sunroof
but i will get him to read this post
will ask him,if he has replaced any of the seals to
might be worth getting them all done
were would be best to buy them from?
thanks
Re: water water
undip said
thanks guys
thanks
Crazy Quiffs or e-bay … or do a google search… e-bay in germany may have VAG parts and may deliver to UK?
Your best to have the carpet out for a couple of week and look excactly where the water is coming from, this will make it easier to eliminate certain areas.
Problem you have is whilst carpet is still in the foam underneath collects the water so when driving it will go back and forth from front to backk and spreads all over floor pan and looks like it comes from everywhere, so not giving you accurate answer.
So save your pennies and remove carpet first and watch is the best answer, then makes easier to find and resolve instead of buying things that might not be needed.
When you remove carpet, trust me it is alot easier to spot and correct
Pete :wink:
water water
water water
hope this helps
water water
