water on passenger footwell
(In Topic #75098)
golf i have suffers from water on pass floor .. the carpet is always soaked and electrics are messed up (ie no dash light and temp gauge is faulty)
is this common and what can you do to stop water getting in.. jb
1. Check under bonnet at each end of the bulk head - the area with plastic cover which houses the blower motor, wiper motor etc. At each end of this 'trough' there are rubber drain tubes about 30mm diameter. This whole area fills up with leaves and crud and over the years, well just months, can block up the drain tubes. The water then has to go somewhere, which is over the lip around the blower motor housing and into passenger footwell. Clear any debris/leaves etc out and if drain tubes are blocked, probably the answer!
2. If not above, then check your sunroof drain tubes are working. Open sunroof and get a jug of water and poor into the front corners of drain channel. The water should exit around the lower A-pillar on to the ground. If not, there could be your problem
Let us know how you get on and if solution for point 2 needed!
Best thing is to pull the carpet up and see if there is any obvious signs of where the water is coming from. If its just rained should be obvious. As you are experiencing, such leaks can play havoc with electrics, especially as the fusebox is mounted under glove box. Worth getting on top of quickly as water damage can mean a new fusebox. Here's a few old posts on the subject that may be useful.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=3919
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=3345
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=3329
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=1062
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
markwon said
After typing all that , you beat me to it Hairyarse
Only just but we got all bases covered!! :wink:
