Water in Driver Footwell!
(In Topic #77918)
Car has been sitting on the drive the past few days and when I got in it this afternoon I noticed for the first time that I have a puddle in the drivers footwell
I know this is a common prob with the mk1's but I'm unsure of where to look first to prevent it from happening again.
It does have a aftermarket sunroof, but I 99% sure it's water tight!
Any ideas :dontknow:
Lhasa Green Mk1 GTI 1.8
DubPartz
OR?. The windscreen seal has gone
OR?.. it could be coming thru the door if the plastic membrane has been damaged in the past.
OR?. It?s not unknown for it to be leaking via the hatch or rear lights and to run into the front foot well making you think its come from somewhere up front.
You need to remove the carpets and sound deadening and squeeze as much water out as poss and then dry it in the airing cupboard or similar. If you leave it in, it will never dry out and start to smell a bit??
Alot to go on there.
I will investigate further when it's back from the garage tomoz.
Many thanks Folks.
I'm chasing one in mine at the moment, I think its the windscreen seal but still not 100% yet, I eneded up ripping pretty much the whole interior out, and I think I might need the dash too 8O
good luck, let us know when you find it
black 5 door mk1 GTD
mk1 scirocco Gli in bits
The real pain is taking out the carpets and soundproofing to dry everything out properly.
