water geting in
(In Topic #97213)
water geting in
every time it rains i find water in the pasinger foot well a lot of it as well
iv take the carpit out so i can mop it up every time but i just can seem 2 find were its coming from
any one else got the same proplem??
plez help me hehe
Chairman
I've not had a tintop but a few people I know have and I think that's usuall sunroof, could be wrong here though.
Cabby is usually the window seals, or the seal across the top which then comes through the locking mech.
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Chairman
Follow us on:
Follow us on:
but all the holes aka clutch cable/steering rack is on the drivers side doh
so dont no if it is
also remove door cards and check the plastic sheet is intact, i have a really small hole in the sheet in my polo and it pours water through. whilst you're checking the doors, check the drainage holes that run across the bottom of the door, if these are blocked water can build up inside the door and leak through into the car.
you could always sit in the car while someone stands outside and pours a bucket of water down the outside of your door, or have them hose the car down and you can then look out for where water is coming in.
a bust windscreen seal and/or rot of the windscreen base/surround could potentially lead to water getting in.
hope this helps.
cheers.
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
but il have 2 get me sister 2 hose the car of and il see were its coming in then i think
if i can find it il just have 2 leve carpit out till summer time haha
The carpet near the sills is dry as a bone so its not like its coming through the door. i dont have a sunroof either. only happens on that side aswel :/
DannyEss said
i have this problem but its behind the drivers seat where the passenger in the back would sit.
yours is a different problem my friend. my moneys on it coming in though the boot. is it wet under the seat ?
Member 125 - 2005
rear lights, rear boot seal, drain holes in front skuttle tray, seal around heater blower, any gromments on front panel, corners of windscreen (can drip straight onto fuse box), plastic membrane in doors, door drain holes, whereabouts are you ? if you need a hand/ hose pipe let me know.
