Water dripping onto fusebox
(In Topic #158790)
mark
Member 125 - 2005
Although I know its not the drainage holes, checked them. Not to sure about grommets though.
I was just about to fit new carpet as well, drove back from having bumper sprayed water on the floor!!!
Thanks again
Mark
I have a bit of rust under the windscreen seal above the fuse box could this be the culprit? I don't take it out in the rain normally. Is it a windscreen out job?
God they are money pits ha ha.
Mark
I do have another mk1 I could nick it off?
Mark
Member 125 - 2005
At first try using silicone sealant or windscreen sealant.
Thanks I will pop out now and try it, I have some BMW window sealant.
Do you think this is my problem them?
Mark
Member 125 - 2005
I have fitted a new aerial so I shall check that, not to sure about roof door seal I would have thought I could see it dripping in there?
Mark
Ive also got rust stains above the fuse box….
Ive had to replace the fuse box already, cleaned the rain tray and all drainage holes but it still leaks.
Im now half tempted to hole the windscreen and get a new one off insurance to to get the seal around the screen redone… naughty I know :/
I was also thinking of using stonechip spay to spray the whole rain tray just to be sure its not leaking from anywhere that I cant see.
help needed cf_emoticons__BangHead:Jonathan
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
Good luck.
Mark
