USED HOOD GOOD OR NOT ?????
(In Topic #118983)
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=12313
this should gove you some idea
Once you release the c pillar trim lift it up and you'll see the 2 tensioning straps these are held to the back of the frame by 2 bolts. side tension cables dont need to be touched, but be aware they may not have been fitted if the fitter was ignorant/lazy. the rear tension cable needs to be undone to get the back of the hood off anyway, so if included check the condition of it.
I have been told today that they came in two different sizes and that a hood from a late clipper may not fit my early 87 gti
Is this true or just a load of old tosh? as they said, it can differ up to 2 inches from front to back which i doubt as everything vw is too accurate surely?. blimey theres more to this wanting to keep it origial than meets the eye eh ?
actual car chassis is the same! Oh and obv power hood not the same as manual, can convert power to manual easy enough but other way requires a lot of extra gubbins in the boot, brackets need welding on etc. also the boot gets a lot smaller!
edit: my 83 cab has a late spec hood on it, from an 88 IIRC? bolted straight on
will keep you informed . cheers andy
