Uh oh! Leaky doors!!
(In Topic #126992)
You can actually hear it dripping inside the doors lol. The worst one is the passenger side.
My question is, new doors or new seals?
Bearing in mind the doors are still fine as the car has been garage stored for the last few years. Plus I have my weather cover on order as we speak. I also have some dessicant on hand to dry up.
EDIT: OK, so I've worked out the issue and its defo new scraper seals that I require, does anyone know where I can get some for less than £46 a pop??
Anyone for tennis?
good tip for you, cut a 2nd piece to half the height of the door and stick it along the lower half of the door, tuck the bottom edge inside the door, then stick your top piece on. this directs all the water straight into the bottom of the door, rather than allow it to pool along the base of the water barriers and seep thru. waterproof duck tape is what i use to stick them down as its easy to work with and it will peel off again without any difficulty
drove my cabby for a while in the winter without any scraper seals at all, no leaks inside the car at all due to well made vapour barriers
Anyone for tennis?
thanks
My research has told me that Crazyquiff will have some in in september, for a bit less.
Unfortunately VW don't make em no more so its a case of waitin around or getting lucky.
Anyone for tennis?
