Swimming pool
(In Topic #88443)
Swimming pool
My Golf has stood for 1 week. Just checked it and the rear foot wells resemble a swimming pool Its taken 6 large towels to mop it up. I left if for 30 mins and the carpets are starting to get soaked again 8O Its not raining at the mo so i dont understand that :dontknow:
Anyone got any ideas what might be causing this :cry:
1991 MK2 Golf G60 20VT
1991 MK2 Golf GTI 16V Oak Green
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
more than likely theres water built up between some panels could be getting in the rear of front but somewhere is full!!
if u take carpet out and try and track the water back to where its coming from
hello!
(there is one each side.)
It will start to smell and steam up the windows.
Isn't that a symptom of something else wodders?
I had a problem similar to kriss a lilltle while ago then I put the roof up :wink:
have you got a sunroof?
Touch my car …………………. feel my wheels
operor retineo patria parvulus depressus vos
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
Every day's a school day I suppose.
Tian :wink:
:dontknow:
samwilko said
Mine did exactly the same, its coming in through the bottom of the door where the membrane is knackered. Made a new membrane and stuck it on but it keeps lifting off after a few days. What would anyone recommende to stick it down with?
:dontknow:
Silicon.
Tian
The rear window seals also appear to be letting in water, so i will get some silicon sealant and get that sorted.
Big thanks for all your help - i'm slowly learning ops: If it still leaks then i will have a scratch my head :?
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
Did this on a fibreglass Gilburn invader i had years ago.. solved the problem but not the cause!
Just rememberd, the Gilburn came with a small plastic bucket in the back foot well… wondered what it was for until it rained!
Garage:
83 Mk1 Golf GTi Campaign - Mars Red - Totally Standard
78 Honda Civic 1200 Hondamatic - Silver
07 Honda Civic ES 2.2 CDi - Black, all the options!
kriss said
I presume i could just put in a replacement rear inner wing :dontknow: Is there anyone that still sells them :dontknow:
You may be able to plate it rather than replace the whole wing.
markwon did a thread on replacing that part of the wing. Definitely worth a read
HTH
Rich
Twitter Manager
droogeh said
gotta sunrrof?
I got this problem too (pics to follow) seatbelt anchorage in the rear is coming away from the car! looks like water is coming from under the headlining over the rear quarter headlining. Is there a tube from the sunroof drain that would have perished? or is there a channel blocked perhaps? anyone else had the same troubles?
