steering wheel removal
(In Topic #80236)
Its a big-un - from memory 32mmm?? I had to buy a big socket from Halfrauds to do it. Will be tight too so you may need someone to hold the steering wheel whilst you undo it.
Easy tho :wink:
just fiddle around with different sockets, but it is easy.
It will be a tight fit so i socket is best advised not an open ended spanner etc.
Andrew 2
The wheel will probably be stuck on the splines of the steering column quite hard so you'll need to knock/bash the wheel off with your hands while sitting in the drivers seat. Leave the nut on a couple of turns to avoid the wheel hitting you in the face when it comes off.
:mrgreen:
Put the steering lock on while you undo the nut, but straighten up the wheel before you remove it from the splines :wink:
Easy :mrgreen:
Hairyarse Posted: Fri Jul 07, 2006 6:40 am Post subject:
Yep, good tip on leaving the nut on slightly when pulling off - I learnt the hard way!!
i learnt this way the first time i removed the wheel, and it dont arf hurt if it cracks u in the nose!
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
