steeing wheel/horn problems **please help mot soon**
(In Topic #79555)
Horn trouble
the brass ring at the back of the wheel should be touching the little strip of metal coming from the switch on the steering column, this is the live from the horn.
Sounds more like you it is the switch in the wheel in the on position all the time. I'm not sure which wheel you have, but in mine i just pulled out the centre horn cover where the switch is and bent the contacts so that it only made the circuit when the horn was pressed.
I presume when you take the centre of the wheel off the horn stops sounding.
Ash
1983 Gti track day weapon!
Hope this is your problem as it's an easy fix !
Cheers,
Mark
ill get down to the scrappys for a look for one
Ian
'89 Clipper Auto and '92 GTI Cabby
deffo
Ian - sounds weird that. You could take the wheel off and have a look if you've got the spacer / spring there I suppose. If you look between steering wheel and top of column switches, there should be a clear gap. On mine it's now about 4mm or so. All you should be able to see is the contact strip coming off the column switches at the bottom and touching the wheel. If you can see anything else then that could be the problem (eg, screw heads sticking up, etc)
Good luck with it !
Mark
Ian
Cheers,
Mark
Life Member
