repair pannels
(In Topic #103699)
repair pannels
Not to Shaw if this is the right section but here goes ,Can i get the chassis section where all the the small pipes run though from the fuel tank and also the inner bit of the arch on the same side where it goes over the filler pipe and the seat belt bolts to sorry if I'm a bit vague but this is me first restoration project much appreciated mooey
did you stop for breath when you wrote that!! 8O 8O
It sounds like you need an inner rear arch and bit of floor pan??? someone else will be able to confirm this! try Rich at Crazy Quiffs, He should be able to get what ever bits you need.
Ad's posted bottom left!
