removing glue
removing glue
My golf is nearly stripped ready for baremetal respray heading to the bodyshop next month .Has any one any ideas on removing glue that holds the  door seals  on,and the sidestripe glue.
  I try and get some photos up before it goes to the sprayshop if i can work out how to post them.
          thanks  mark
76 ?
78 gls
83 gti 5v
Heatgun and a scraper maybe?
Or at work we use Servisol Label Remover which we get from CPC but you need to set up an account (great site though and has so much stuff you'd also want!
Hope that helps and get some pics up of the before and after spray job  :wink:
_________________
'82 Black 1600 GTI - Getting Better
Yea tryed the heatgun .It is working but very slow.thanks   for the link    interesting site
              mark :D
76 ?
78 gls
83 gti 5v
For removing residue of glue (rather than larger lumps of it), use lighter fluid - it contains Napthalene, a solvent that dissolves glue really well.
You still might have to start off with the heat-gun/scraper  :x , but this will help you finish easily  :)
cheers will give the lighter fluid a go.Heatgun has removed most of it just the residue to remove
       mark
76 ?
78 gls
83 gti 5v
3M Do an adhesive remover with a strong orange scent .we have it at work, its called 3M Cleaner spray 50098 Citrus Based cleaner, Try this, it works! :D
Jjl.
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
thanks for the info lakesk8,i went down brown bros to get some 3m cleaner.They didnt sell 3m but i got some bodyline glue remover was less than a fiver for 1 lite .
    Going to give it a try  today ,will let you know if its any good :D
     mark
76 ?
78 gls
83 gti 5v
