Rear wheel arches
(In Topic #75646)
Rear wheel arches
Not much use unless you replace the lot in one go . Better to use a mig and grind / sand down the welds as you go . I have a spot welder and only used it for the top of the sills replacement and the front sills part . When you get to the narrow bit on the floor its no good with out tiny bent tips as there is only a few cms of room .
Mig you can't beat it ….
Cheers………
