Rear Seat Belts Mk1 Tintop
(In Topic #150149)
Help please on how to fit rear seat belts. Where & how do they fix???
My Golf was not supplied with rear seat belts but I am in the process of buying a set. Would any of you be kind enough to post some photos on here showing the way they are fitted. I have found two threaded holes on the floor of the boot but everything else is hidden behind the headlining. Also unsure how to thread through the small aperture at each side of parcel shelf. Really appreciate any guidance.
Chris
Chris
In the process of doing this myself. With regards parcel shelf holes, the belt reel bolts underneath these just below the C pillar. From here you should be able to pull the belt through the hole along with its attachments. There will be a sort of triangular piece of metal on the end of the belt. This goes in the holes in front of the rear inner wheel arches. The other clamp you have on the belt is to mount on the c pillar. Feel the inner c pillar and you should be able to feel a rectangular indent, within this you should be able to feel the hole.
If that doesnt help let me know and ill crack out the tape measure when I get home
Why did I start this
Thank you so much for the kind post - it was extremely useful advice and very much appreciated - apologies for not thanking you earlier, it has been a really busy start to the year. I have just had the anchor points welded in, so should be able to fit the seat belts over the coming weekends - good luck with your project.
Chris
Chris
No worries. Its nice for me to be able to help someone instead of the other way around
