Quick couple questions..
(In Topic #93942)
I've got a pair of these -
and I was wondering, - what exactly do you do to fit them? ! I know this sounds like a stupid question, but the shell I've got is fairly solid but there is rust in a couple of these places where the plates cover, do you cut most of this way? Anyone got any photo diary pics of successful use - sorry if this doesnt make sense, but I know what I'm on about and if noone else does, I'll take pics to prove what I mean -
seeing as there is heavy rust inbetween the bolts and around the edges, you don't just slap the panel on top..??
Also, I've managed to, I know, sacaralidge, break an back axle bolt taking the axle off - how do I fix this?
Ta..
what do I do about this broken bolt? Any suggestions?
You can also drill down the middle of the hole to remove the majority of the bolt and screw in a thread tap that's slightly smaller than the bolt thread to remove the remainder.
Whatever happens it'll probably be a mare of a job, just to warn you.
Yradave says relax.
07792646786
07792646786
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=25387&highlight=yrs
e said
Thank you - there is quite a bit of it left - so it's a stud? You can buy new ones? Cheers
Well it kind of is once the hexagon head has snapped, but originally will be a bolt.
Thinking of something along the lines of this that'll grab the bit of bolt sticking up and twist it out.
http://www.machinemart…-4-pce-stud-extractor-set
Or maybe this.
http://www.machinemart…-drill-screw-extractor-se
Yradave says relax.
07792646786
07792646786
