Pierburg carb 1.8 running fault
(In Topic #73374)
I've changed plugs, leads, dissy cap, coil, ignition module and fitted a secound hand carb (ebay) but had to swap some of the carb ancilleries over, eg. a small vac pot on the right hand rear, a water valve on the front, BUT STILL HAVE THE FAULT.
HELP!!!!
Re: Pierburg carb 1.8 running fault
cool thats great advice I'll look at it tommorrowalexh said
have you checked the filler neck? if newish is the tank full of rusty metal from the previou filler neck? the way to check the tank is to remove the rear seat and remove the inspection plate to gain access to the sender unit. if you take this out you will be able to check the fuel pick up pipe and also the tank. if it has rust in then it's tank off and clean out
You will want to check the rubbish autochoke thing isn't broke either.
If I were you I'd be on the hunt for a twin choke down draft weber replacement!
