Noise from air vents
I'm having trouble with excessive wind noise through the front windscreen demisting vents. Does anybody know how i could go about investigating the problem further or has anybody experienced similar problems? Any suggestions would be much appreciated.
Shyam :banghead:
Does the noise reduce if you slide the ventillation slider off of the windscreen position?
Mine makes a lot of noise as well - I read somewhere that it's usually down to the fan running against the housing as a result of being off-centre.
Somewhere on the WWW there's a guide to refurbishing the fan.
try;
http://experts.about.com/q/Volkswagen-Repair-833/VW-Golf-heater-only.htm
see also;
http://www.vintagewatercooleds.com/tech/index.html
Although this isn't the site - it does have lots of useful stuff on it and links.
I think it's fairly fiddly to get at the fan, but once you do it's relatively easy to slip in a pice of paper/card to moved the fan so that it doesn't run anymore.
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
I've tried turning off the vents to the windscreen but that doesn't help. If anyone has had similar problems i'd be grateful for some help.
I once had a noisy side vent,it was a leaf in there causing the noise.
Maybe worth a look?
Neil.
Volksdevil.com - Gone but not forgotten | CorradoG60.co.uk
What sort of a noise is it you're getting, knocking? squeeking? creaking? :dontknow:
