New Hood Help
(In Topic #138572)
New Hood Help
looking at a cabby but on the inside of the hood the clips have apparently come out any1 have some or know where i can get hold of some?
What clips are you referring too?
A picture of where and what appears to be missing will help us, help you.
Chortle
The top is made up from 4 components and fit in order on a bare frame.
1) headliner, the bit you see looking up from inside the car.
Held in place by 2 rivets at the front in cup washers and across the front header by a bar and screws.
Glued to the centre rails and hung on straps in the rear corners and stapled across the rear.
Under that you have the interliner.
Underneath is the interlinear and pad (these usually deteriorate and the pad wears thin)
On top the hood it's self, again glued across the front and held in with the bar.
Glued to side flaps at front, held down in position with 2 side cables. 2 straps come through the pad assembly and are riveted to the frame. These stop the hood from bagging out at the rear when folded down.
It's glued to 2 further flaps at the rear quarter. Held into place by a cable at the rear channel.
Whereabouts are the clips located on the hood or frame etc?
A general whereabouts could help.
Are they at the front or sides or rear?
Chortle
piccy up whats missing and we can let you know
is it these?
ANY OF THOSE POINT IN THE AREA?
Chortle
FAIL
rubjonny said
FAIL
MEGA FAIL LOL.
