need advice on fitting dashboard
(In Topic #113646)
could anybody help will a early dashboard from a 1980 model fit a 1982 model without any ploblems does any wirring have to be change would be gratefull for any advice
What are you exactly chainging the whole dashbaord or the switches and clocks etc aswell to 83??
Bolt holes should be in the correct place on your '80 dash so will fit straight in
Info on wiring here
Info on wiring here
i wanted to put a early dash in a later model if this could be doneross_m said
Info on wiring here
Yes it will fit straight in. The info in that thread still stands for you as I have an s2 engine and loom in my '80. It had an s2 dash when i got it for some reason and I swapped it for an s1 dash so at the end of the day I did the same thing your wanting to do
