Mk1 restoration help"!"
(In Topic #99251)
I thinkin its going to need the following
2 x outer rear arches
2 x full complete inner rear arches
1 x lower valance
2 x sills
and a whole lot of time on it the only bloody thing is that welding isnt up to doing the job
Here is some pics
so from this
to this
Now for the bad parts
Do you think it to far gone to reapir ??
any comment welcome
Cheers Nick.
What is the condition of the front inner arches like? Given the state of the rears, they may be badly corroded too. If they are, and you've no particular attachment to that shell, I would look for a replacement in better condition.
That said, there are plenty of pattern panels (of varying qualities and prices) available if you fancy repairing it.
HTH
Rich
heres some pics
so what you think? Does anyone have a good bare shell for SALE?
Cheers Nick.
When you look at the car as a whole it probably gets disheartening, but tackle each area at a time and before you know it you'll have broken it's back and there will be light at the end of the tunnel
I am going to learn how to weld properly as I think you can't beat the feeling of doing something yourself
check this out http://forums.vwvortex.com/zerothread?id=3742832
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
Nick - have a poke about under the underseal on the inner arches to see what the metal is like - from the pics they're not as bad as I thought they would be.
Have a read of markwon's resto thread as this has loads of bodywork in it too…
HTH
Rich
see http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=29452
Rust
When the cars were new, no-one was aware of where they were going to rust, but now we all know where they go and there are some very good rust treatments and waxes available these days
A restored, properly rust-proofed car should last a good while before any more work is needed
They're VW, not Alfa
Nick.
Help need on what to do!
Just wanting some help or should i say someone to change ma mind, i started to take off the waxoil and underseal and ive ended up with this now is the car in to much of a bad state to repair ie wasting money when i could buy a more soild shell.
Here is some pictures of the front inner wing that has put BIG doubts in my mind as to what to do
Passengers side inner wig where it meets the door frame.
Drivers side is not too bad really
Opinions are very welcome on this one
Cheers Nick
phil
1981 1600 gti was silver now mars red!!
<a href="golfsig.jpg picture by barty2 - Photobucket"><img src="http://i286.photobucket.com/albums/ll82/barty2/golfsig.jpg" border="0" alt="Photobucket"></a>
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=41539&highlight=
I'd say you have done too much already to scrap it! Better the devil you know. At least you now know all the bad areas on this one, if you were looking at replacing it with another you could find alot worse.
You have a great set up there, at least your not out in the road doing it! Great images as well, really help full as i know i will be under taking the same job on my Campaine some day.
Doing a bit of welding on my Driver at the moment on the rear, access is the worst bit but you seem to have that sorted.
You seem to have it sorted by making the repaire look worse before you repair it and removing all the rot before patching or replacing. Feels like you are chasing your tail at times i'm sure but keep it up Mate. before you know it youll be showing it off with pride at all your hard work.
cheers Domma………..
Secretary
Its a pity that my project wasnt further on, as i have two good front inner wings on my donor car that im eventually going to chop into lots of spare bits.
Good luck and keep us posted.
