mk1 jacking point panels available ????????
(In Topic #106193)
hi all my caddy failed its mot today on both front jacking points rotton anybody know if they are available as a panel repair section would make the job much easier
Don't think so. CQ does a floor section but I don't think they come with them on. (You'd have to check to be sure though). For Hadrian repair panels, there is a guide here, but you need to check with your local stockist for availability, since they run out of stuff, and sometimes if there's a demand make another batch of previously obselete stuff:
http://www.fastgolf.or…pa=showpage&pid=32&page=3
One of mine was rotten but it is the inner sill that causes the problems. Replace this (can get a panel from crazyquiff) and you can put some bracing in the space above the jacking point…
Worked for me anyways…
cool thanks for that when the weather gets abit warmer ill have a proper look and poke around with it i gotta do both sides and the inner sill along where the seat runner is on the drivers side
