MK1 golf/ jetta coupe windows
(In Topic #154040)
do mk1 3dr windows all fit on a jetta coupe?
Been looking at getting some opening quarter windows for my jetta coupe but all the screw in type ones that i have found have been green tint glass,
iv found a front windscreen, both front side windows and rear quarters from a mk1 3dr all in green tint,
now the the question is i know the front side windows will fit,
im guessing the windscreen is the same but are rear quarter windows the same from a mk1 3dr to a mk1 jetta coupe?
also does the rear windscreen come in green tint?
Ameet
Last edit: by ameets
rubjonny said
yes and yes
sweet and do you know if the rear pop outs come in green tint, all the ones iv found have been clear…
might be worth asking local glass tinters, im sure they could match somethign up for you. you want the pros for this i recon to make sure the edges are right, if its even possible that is as i assume the edges of the tint tint iarnt supposed to be exposed to the elements. maybe fit a U channel trim strip all around the outside to hide the edge/seal it?
