leaky cabriolet, HELP!!
(In Topic #104281)
On cabbys there is a sponge gasket that fits between the metal rubber seal holder and the hood frame where the hood covers over, the seals sometimes perish and the leak starts, plus you need to put plenty of sealant arond the plastic plug and screw fitting. You may need to adjust the windows to meet the roof rubbers. They should just push the rubber around the top of the windows. You will need to remove the door panels to adjust the mechanism or the door hinges depending.
