Leaking rear window on cab
(In Topic #78401)
Is it easy to replace the old window surround? Or does any one know some body who can carry out this job for me in the Derby area? I'm will be using the car for a fortnights holiday shortly (hooray) so it will be outside all the time, rather than in the garage. I'd like to get this sorted before I go rather than bailing the car out every morning (the weather in Cornwall can be pretty dire at times!!).
Any advice would be greatfully received.
Rich
Re: Leaking rear window on cab
Richb4 said
Closer inspection revealed that the metal surround onto which the glass is attached appears to be corroded, in fact disintigrating. I think this is the source of the leak. The rest of the hood is only a couple of years old, but the window and surround were a carry over from the old hood.
A new frame is ?200 from GPC….so most people don't bother replacing it when the roof is replaced…..FALSE ECONOMY…!!!!
Have a look at Our Hood Saga
I think it can be done easy, just hope that the new frame lines up with the 'hole' and there is enough material left to staple the material to the frame. Make sure that the new frame is liberally coated with hammerite….
Rich
