Leaking Cab.....
(In Topic #88727)
Leaking Cab.....
Noticed yesterday after all the rain of late that the rear footwells of teh Cab are damp… Can't see an obvious way in either.. It's been almost bone dry right up until this weekend (couple small drips from header rail/release handles in absolute monsoon rain)…
Any ideas where I should be looking? All the window seals seem tight and it only seems to be rear footwells… not obvious water trails down door/1/4 cards…
Is your boot dry?
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
If the roof is good then the most common things are to check the two drain holes in the scuttle area under the bonnet, they might be blocked and also check the polythene membrane behind the doorcards, this could be split or missing altogether.
Watch out for Wooders, I'm sure he'll have something to say. :wink:
Yradave says relax.
07792646786
07792646786
no. i'm reforming.
That was quick.
Bet you want to say something, though.
Yradave says relax.
07792646786
07792646786
i have serious teeth marks on my knuckles
Hehe, I wonder if I can make you hit bone.
Would it go something like 'if you had a proper roof it wouldn't leak'?
:twisted:
:twisted:
Yradave says relax.
07792646786
07792646786
Web Team
when my rear footwells were getting wet the water was tracking from the rear window and around the rear lights took both out sealed around them with clear silicon and it has been bone dry ever since hth
Merely a joke.
Nothing more, nothing less.
Yradave says relax.
07792646786
07792646786
Cheers Terry/Ross…
Will check boot tonight.. will also free out the scuttle drain holes as I think they maybe the main culprit as the footwell carpets seem slightly damp too.. But that could just be wet feet! All door, rear1/4 membranes appear to be intact too but will double check them and the associated drain holes too… Parcel shelf carpet's dry so guess not rear window…
I was expecting the "Get a proper roof" comments however a mates Mk1 Tin-top leaked worse than this so
my parcel shelf stayed dry it was running down behind that found out by getting someone with a hose pipe while i was inside with seats down and a torch
Was scuttle drain tubes, no leaks since.. Yay… Same as Corrados..
Top tip as we go into this time of year.. Check the scuttle drain tubes are clean (Obvious first place I should have looked! But the scuttle was clean, obviouslt previous owner had cleared the scuttle area and not the tubes! )
