Leaking Cab.....
(In Topic #88727)
Leaking Cab.....
Any ideas where I should be looking? All the window seals seem tight and it only seems to be rear footwells… not obvious water trails down door/1/4 cards…
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
Yradave says relax.
07792646786
07792646786
Bet you want to say something, though.
Yradave says relax.
07792646786
07792646786
Would it go something like 'if you had a proper roof it wouldn't leak'?
:twisted:
Yradave says relax.
07792646786
07792646786
Web Team
Nothing more, nothing less.
Yradave says relax.
07792646786
07792646786
Will check boot tonight.. will also free out the scuttle drain holes as I think they maybe the main culprit as the footwell carpets seem slightly damp too.. But that could just be wet feet! All door, rear1/4 membranes appear to be intact too but will double check them and the associated drain holes too… Parcel shelf carpet's dry so guess not rear window…
I was expecting the "Get a proper roof" comments however a mates Mk1 Tin-top leaked worse than this so
Top tip as we go into this time of year.. Check the scuttle drain tubes are clean (Obvious first place I should have looked! But the scuttle was clean, obviouslt previous owner had cleared the scuttle area and not the tubes! )
