Joggler tool, worth it?
(In Topic #75635)
I have a hand joddler from Machine mart . Good bit of kit BUT …. i should have bought the air powered one . Reason being that the hand one does not produce a good step in the panel but the air one does and being air powered you can make loads of passes until you have a good step for welding . Its all down to the effort required , and sadly the hand joddler is just not up to the job , also it has a punch at the other end and i have found the hole too small to get a succesfull weld in when button welding .
Cheers……….
