inner wheel arch removal
(In Topic #98843)
I am trying to remove the passenger side front inner wheel arch so i can replace the antenna.
I have removed all the screws holding the outer wheel arch trim (clipper trim) and have removed all the screws (4-5), holding the inner wheel arch. When i try and move it though it does move a little but still seems firmly fixed. I dont wanna get heavy with it in case i damage something so am wondering if there is anything else i need to do? :dontknow:
jez
Picture below, to give you an idea.
The white wire is one I pulled through wih the old lead, this was then used to pull the new lead through. Did it this way just to reduce the chance of snagging as it goes through the back of the dash. One quite tight spot just behind the glove box on myn but with patience it went through eventually.
dont forget to put all the rubber bungs back as well. good luck.
1988 1.8 carb Golf Clipper
