Humph! Clutch busted through bulkhead!
(In Topic #91783)
So, thursday, fitted fan belt, charged battery, got alternator checked, so far so good. Reversed out the garage, BANG, WTF!! Clutch not working!? At first i though it was the cable that snapped, but got it towed to my mates workshop, had a look an it turns out the bulkhead is rotten an the thing got pulled through!!!!
I've had a look around an i see you can get a kit with a patch for fixin it, common problem looks like?
I've been advised against this though, in case the patch gets pulled through as well.
Has this happend to anyone here? Whats the best action to take? Patch? Weld?
Any info would be great!
In fact, out of all 3 of my Mk1 Golfs, 2 have this panel - the other is an auto!
GTG4V1N said
Cheers, im thinkg about welding a bar aross the whole bay an drilling it?
Won't look as good, but perfectly okay as a repair. I'd make it a flat plate of metal, rather than a bar, though.
If you just put the sticky backed repair plate on it should be fine, welding up that area requires an element of luck or stripping out under the footwell as theres a fair bit that can catch light from heat!! and personally i would rather have a bare metal plate than a frazzled car! you can hardly notice the plate once its fitted and any mk1 oficinado will know exactly why its there! plates about ?10 from gsf and places like that
Don't let things like that put you off the car, its just one of its quirks that you will get to love (and fear!).
'90 MK1 Clipper, Black - Sold :-(
BMW 323i 2.5
BMW 323i 2.5
Re: Humph! Clutch busted through bulkhead!
This has probably happened to everyone on here!!!
All three of ours have been patched, and Rach's has too.
Once patched with the metal plate we've had no more probs
Good luck!
Humph! Clutch busted through bulkhead.
Solid Gold Easy Action
Bob.
Mk1 golf gti campaign… 16v ish…
MK3 gti 16v
is the mk1 rusty? depends what you mean by rust….
MK3 gti 16v
Website Manager
