How to remove and renew outer window scraper seals?
(In Topic #133717)
Just bought a new O/S front outer window scraper seal for my cabby but can't work out how you get to change it?
Have removed the door card but I am left with a long black strip which goes along the top of the door and over the door pin, does that come off somehow?
I can see into the door where the glass is and there seem to be some retaining clips which hold the seal in place but can't work out how to get in?
Any help most appreciated, cheers guys,
J
2007 Passat 2.0 Sport Estate TDI 170PS (The Bus) 2004 Golf FSI 1.6 (The Wifes) 1988 MK1 Golf Gti Cabriolet (The FUN!)
Cheers fella, never done one before and at £30 a pop won't be doing them unless I really need them!
I do believe that they are designed to work without the original VW metal insert strip which you remove though as I could not work out how to refit it using the metal strip but without it fits quite nice. Has anyone else fitted these replacement seals???
Looks a lot better as my old seal was down to the metal!
These are just clipped into the door top slot.
You don't need to remove anything.
Just prise them up they are held in place with clips.
