How safe is stainless steel?
(In Topic #77369)
His figures show even marine grade stainless steel to only be just as strong as 8.8 strength mild steel. VW bolts for suspension are supplied at the next strength up (10.9). It also appears that stainless steel has a much smaller window in which it starts to deform before ultimately breaking 8O .
I'm sticking with stainless on non-critical areas such as fuel pump brackets, fuel tank straps etc but have shied away from using it on suspension. What are other peoples experiences/knowledge in this area? Is this guy getting carried away with his stats :dontknow:
1983 1100 C
1983 1100 C
then from my local nut and bolt supplier .
Can't see the problem .
Stainless looks smart , is strong and don't rust .
ops: I should add though [edited post] that the original steel items on the suspension etc are still used , i meant i have used stainless on the pretty parts and things like fuel pump mounting etc . Every self tapper replaced came from the stainless tin . Hope that clarifies it .
Cheers…..
I may be talking out of my backside but it's my thoughts anyway!
In the machinery I'm involved in selling we very occasionally get involved in medical or food applications where certain parts are made in stainless and there aren't any particular strength issues I'm aware of.
Anyway, enough of my 'layman' babbling, perhaps someone with some real experience of this knows here?!
Don't you need to be careful when welding stainless steel, vague memory on my welding course about it giving off nasty fumes. Then again maybe I'm gettting confused with the galvanised stuff :dontknow:
I know naaaarthing, I know naeeeerthing signor Faaaauuulty :wink:
I'll let you do the road testing though Chudd
1983 1100 C
1983 1100 C
Remember, VW made the last car in 1992. After that they started making vehicles.
If VW recommend Grade 10.9, stick with it as they have put a lot of thought into this.
I am going to use Stainless Steel fasteners on my mk1 but they will be used to clean up the look of the car really. Use them mainly in the engine bay for low load bearing parts
The stats given show the best stainless vs 10.9 mild
Marine Grade Stainless - 116,000psi (tensile strength) 87,000 psi (yield strength)
10.9 Mild Steel - 151,000psi (tensile strength) 136,000psi (yield strength)
Yield is the point at which the metal starts to deform and tensile the point at which it ultimatley breaks. According to this, the best stainless will have long snapped before 10.9 starts to even deform.
1983 1100 C
1983 1100 C
So if used in suspension components, which do flex a little, then the time to failure will be shorter.
The same aplies to exhausts, stainless ones dont rust but how many poeple complain about cracks apearing 8O
If it a low use car stainless will be good as it will not deteriate in the garage, daily driver use mild steal :wink:
Rob
On the food/medical machinery front stainless is the only option for cleanlenss, but the service schedule would be written to change high stress items more frequently than if they could use mild steal.
Audi A4 1.9TDI - Gone
muttley racing ftmfw
concluding that stainless steel should not used for any critical areas i.e suspension.
On that i agree and have edited my post above , i meant that replacing all the pretty and non essential load bearing bolts, nuts, self tappers and screws is a great idea . But leave the big ones alone .
Cheers……..
With you all the way with stainless - I've used it on bikes for 20 years and a mate runs a business supplying it. He's never heard of a failure but I wouldn't use is on critical suspension points and he doesn't recommend it. And if you want it to come undone again use plenty of copperslip!
Barkstar
