help
(In Topic #80696)
help
The problem is that it will not start first time it takes about 2 minutes turnin over before it bursts and splutters into life. it will run fine when warm but every so often it will hesiatate and mis. also when comin to a holt it sometimes stalls but starts up fine.
please help
http://img65.imageshack.us/img65/2838/s5000021agm0.jpg
I may be wrong but is there a small filter in the disribution head like on the later VW's, I had a similar problem on an Audi when this filter got dirty.
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
changing
filler neck
fuel pump(twice)
fuel filter(twice)
checked fuel lines, DO clean them out tis a must
dizzy cap and rotor arm
spark plugs
ht leads
then go and find some FORTE specialist injection cleaner and run that through
now shes runnin fine….touch wood
rebuild in progress....
cabriaulait said
having had this problem now for ages and got it sorted by
changing
filler neck
fuel pump(twice)
fuel filter(twice)
spark plugs
ht leads
Do you know which one it is. Mates tryin the injection cleaner at the mo. i reckon its the fuel pump sounds like its dragging air in. like its making bubbles or is this noise normal.
if the fuel pump sounds like its 'bubbling then maybe it has a leaky pipe to it, is theyre any sign of fuel leakage at the pump, youll be able to smell it if theyre is.
the whole fuel system has to be completely clean throughout basicaly with no leaks,
i had leaks everywhere, and i was wondering why i was getting a misfire
