Help with Respray
(In Topic #134775)
Help with Respray
1989 MK1 Golf Clipper
1999 Ford Cougar 2.5 v6 (soon the nightmare will be over and car gone)
not a polish if unsure test it on a spare bit of metal
if it aint broke dont fix it but betters allways better
It is metalic green with peeling lacquer which looks a mess. I tried to flat the peeling lacquer back and then buff it up but I failed!
Anyway, after giving the panels a buff up they seemed to look misty and murky :-s is it not good practice to polish over lacquer with a mop and g3?
g3 leaves all white under the doors and bonnet jams murka dont and with g3 you use loads of it, murka just a little goes a long way.
The deep shine is due to the clear coat and not the paint underneath, Sanding down paint will just give you a better looking finish as there will be minimum Peel effect.
As a rule painting onto a polished surface is not a good idea! you are asking for a paint reaction that way.
g3 is crap murka compound is the best. and you dont need water can be used dry.
i cant find this Murka product on line, where can you get it from mate?
1.8T CABBY
1.8T CABBY
