HELP with electric roof and places in yorkshire to one?
(In Topic #127380)
i have to open the boot flick the switch and close it manually.
it opens ok on the switch no probs.
any ideas what this is? is it just a case of topping up the hyd fluid?
also my roof is looking very tired now….was thinking of trying to renovo it but
just wondered how much more it would be to get a replacement froma decent
place in the in the yorkshire region?
any help is appreciated
thanks
what i dont know about engine work…
is worth knowing about
***PM for all your powder coating needs***
http://cgi.ebay.co.uk/Servisol-Super-10-Switch-Contact-Cleaner-/260433010389?pt=LH_DefaultDomain_3&hash=item3ca3045ed5
it could be a faulty relay too, so ask in the elcetrical section for the location/number etc.
Insofar as the hood is concerned if you have a look at the various trimmers in yellow pages etc, for a quote.
There is carhoods northern who advertise on here. You get a discount being a paid member too.
Or you could go the DIY route and fit your own, depending on your budget etc.
Doing your own hood can be a lot cheaper.
Hood new vynil Just over £100.00
New interliner as these Rot away £45.00 plus
Headliner £130.00
I would say a trimmer or hood fitter would cahrge £300.00 just for a hood on it's own.
so can i count out probs with the hydraulics?
ps what is contact cleaner? sorry just never heard of it where do i get it?
thanks
shamstar said
You need to get an auto electrician on the case….its never straight forward…Try spraying some contact cleaner down your ignition barrel or fiddle with your key a little while in the barrel. There is a plunger at the bottom of the igntion switch that will enable the hood once the key is in the slot.
The roof inhibit works off the key making a circuit not pushing a plunger down. :wink:
also this might be stupid but do you have your tonneau partly attached? if so it has a function to stop you litling the hood with the poppers on.
my moneys on the switch being at fault.
if the switch is at fault how hard is it to change…i am a novice of highest order
ps i got the metering head thanks funk star well packaged, have not had chance to get it fitted as yet though
mk1golfgtisportline said
thanks for thye reply chortle….by switch do you mean the button you press to get it up??? its just the reply before was on about the key barrell wasnt it? so to spray the contact cleaner around the switch and down the key barrell?
thanks
exactly, the link that is highlighted click on it and it will take you to a can of the contact cleaner.
My logic was that if it will go up on the switch then I pressume there is power to the switch, in part at least. So yes give the switch a spray with some, as Funk say's lever it out gently. If you take the wires off make sure you remember where they go.
You should really put the tonneau cover on when the hood is down it stops the wind pressure forcing the retaining straps that hold the hood in folds properly, plus it keeps the headliner clean too.
i will always put the tonneau on now…just always thought it made it look abit….for the want of a better word…camp ha but i will take that on board
it does not make any noise when i press the button mate….what you thinking?
Refilled back to maximum and she's working a treat.All trace of noise has disappeared
and she's pulling like new
