Help saggy roof
(In Topic #97759)
Help saggy roof
when you then close the hood with the handles, they should be some pressure to get then to close and once passed a certain point they will close under their own force. To adjust this the hooks are on threads and can be screwed in to tighten etc. Be carful not to make the handles too tight or they may break.
once youve done all that check the alighment of the door and check the window is up tight against the rubber seal at the top.Should press tightly against the seal, causing it to gently roll over.
to check the tension cables open the hood and check at the back should be visable, giving them a gentle tug will tell you if they are snapped etc. Be careful as if snapped but still in place makes a handy pull for new ones so dont disturb too much.
If non of that lot works then let people know.
1988 1.8 carb Golf Clipper
