Grill
(In Topic #105613)
Grill
Hi
Will a MK 1 or 2 grill 1 pcs fit to my mk1 which as a 3 pcs grill??
Old but active in all areas
A Mk1 aftermarket grille will fit. A mk2 grille won't fit. HTH
glad you rasied this, I just bought a grill from someone on here and they said it was a Mk1 grill but it doesnt fit mine due to different fittings? is there a variance between series 1 and 2 front ends? here are some pics.
hook/clip in place of screw hole.
push in clip in place of usual style clip and pin
misfit in shapes.
any ideas
misfit in shapes.
any ideas
misfit in shapes.
any ideas
If its a Mk1 grille, you're fitting it upside down. I don't know if its Mk2 or sometihng else though.
lol cheers for your reply mate but I'm not fitting it upside down, theres the outter two holes which use the usual clip and pin system but the middle two are the type in the picture. it must be from another mk.
its not from anyother mk mate its from a mk1 i will take some pictures of my front panel to show you what fixing holes mine has
<img>
Having the same problem as you dude!
