golf clipper cabrio 1989 speaker help please guys
(In Topic #109434)
im looking for some good speakers for my golf clipper cabrio the fronts are 15 and a half cm and are oval shape and the back seat speakers pioneer 10 cm but there rubbish im looking for good speakers must be able to play music loud not really loud but loud enough if you get my drift plus do all mk1 parcel shelfs fit as i was thinking of getting a second hand one and putting some 6by9 in there any help would be great thanks guys
think that lawsy might even have a cabby parcel shelf with 6X9 holes already in , i will speak to him and get him to reply to this thread…
:cheer: I've got my husband back :cheer:
Web Team
thanks
Re: thanks
essex_gezza said
thanks for the help guys so it look like the best way forward is amp and 2 lots of 6x9 i need a rear parcel shelf if anyone got a spare cause i dont wanna cut holes in mine
i will get lawsy to double check if we have one, however when we had a cabby with 6 x 9's in the parcel shelf when the roof was up you could hardly hear them..
89 Clipper cabrio
06 GTi
06 GTi
you can pick up the bass blockers in any good car audio shop.. and they just fit inline on the speaker wire, the jbl's or infinity's are a good choice however frustratingly expensive for their size!
an mdf panel is the best bet as mdf is stable. there are companies out there that will make you a shelf (try stealth) but they are not cheap.
For the diy method. take your parcel shelf out. draw round it on a sheet of 12mm mdf and cut out. you may be best to add some strength with a peice of 30x12 wood across the back. you can buy acoustic carpet from any good car audio place or have a look on ebay.
secondly neither 6x4 or 6x9 are bass speakers.
for that you will need something bigger than a 10" sub.
for resonable sound quality i'd suggest either 4" components in the front (you would have to make an adapter to fit into the 6x4 hole) or some decent 6x4 speakers. these will handle the treble or high frequency of the music. to filter out anything below you will need to fit crossovers (these are what andybbt is calling a bass blocker)
now to handle the mid range.
i hate 6x9's with a passion. they do not generate good sound quality. i would look at either 6" or 8" components mounted in the parcel shelf (this is not ideal as they are behind you but is a resonable compromise) again with a a cross over but this time to remove the treble and bass so all they handle is the mid range as they are intended.
now to add the bass (which is the bit you most likely want)
a good 10" sub in an acoustic box placed in the boot is a good place to start. add to that a suitable amp (you don't really need larger than 175 watts but then it depends if you want to turn it up and make your ears hurt) most amps act as a cross over so no need on this unless you find it flapping. if the sound is not getting past the parcel shelf a bass tube can be fitted which with help to port the sound out of the boot cavity.
all of this should be done using good speaker wire for the none amped speakers and a good RCA cable for the amp. all of which should be low oxygen and in the region of 100 strands or more. a good head unit will make a lot of difference aswell as will good connections behind it.
ignore the 2 way 3 way speakers that are out there if you can. you want nice full cones to drive the air and have no loss.
there is more but i'm bored of typing this now.
have fun
I wondered what the point was when the roof is folded down it covers the speakers anyway….I have installed new speakers in the rear, but could do with some replacements for the fronts, the originals are still in the pockets, like already stated they don't take to kindly to turned up volume.
