Gap along top of windows on Cabriolet?
(In Topic #142869)
My first problem with my cabriolet. There's a small gap at the back of both side windows:
Is this just a case of getting some new rubbers? If so where can I get them from?
Dunc
COTM Team
Would love to know how to sort this
1.8T CABBY
1.8T CABBY
Arethey easy to replace?
basically look close at the roof, the rubber channels and the rubbers themselves. when the hood is closed the actual frame should be straight over the windows, the metal channels should be screwed direct to the frame and the rubbers should all sit in the channels snug and be in alignment.
the rubbers dont really wear that much, from the pic something is definitely wrong for the 2 rubbers to be that far out of alignment. actually look at them both close to make sure both rubbers are fitted the right way round, maybe someone has fitted backwards
I would look at redoing the foam gaskets and replace the seals back properly, as you go along.
That way you can line them up a bit better.
Remember that there are usually plastic clips located either end of the retainers so remove from the middle and slide inwards.
They usually wouldn't move by just putting the roof down.
With the front one being out of alignment is stopping the widow from closing properly.
There is an adjustment bolt behind the door cards, to adjust the glass height once you have redone them, if required.
Is the roof fully latched down?
This would bring the seals further into contact.
The front seal is out of position by the looks of it.
If that isn't the problem then your door or window is misaligned.
Or you roof frame is twisted or bent.
Putting new foam gaskets would lower the seal slightly too.
A few more pics showing the seals to make sure they aren't ripped or damaged may help.
More than likely it is a case of the front seal not seated in it's retainer properly.
