Front panel removal.
(In Topic #88982)
Can anyone tell me the best way to remove the front panel. I am replacing it with a new one . Its complete with slam panel. Thanks John
both wings first. then spot welds need drilled out, and also a paste that joins the wings to the fron panel.
Hyanes Restoration Manual for golfs is very good on the topic. :wink:
As marsredgti said its pretty straight forward to do,
I have one or two ops: photos of the process
Mark
My cars -
72 Moonraker - http://www.volkszone.c…i/showthread.php?t=304603
MYSPACE
My cars -
http://dubforce.net/pi…files/webfiles/Rallye.htm72 Moonraker - http://www.volkszone.c…i/showthread.php?t=304603
MYSPACE
Drill out all of the spot welds. Make sure you have plenty of drill bits. I snapped about 5.
Took me 3 to 4 hours to get it off…
My Build Thread
Thanks for the info. Those pictures are good as I hadnt even thought about supporting the engine, I always jump in two feet feet first instead of planning it. I removed the rear valance yesterday to find an old rusty valnce under it. If your replacing a panel why dont people do it properly.
You don't need to support the engine - Well I didn't?
What I did do though was to cut a piece of 2x4 the right length to wedge between the two chassis legs BEFORE I cut the crossmember out. The weight of the engine hanging on the two side mounts could pull the legs a bit… It was certainly wedged in a lot tighter once the member was cut out!
My Build Thread
mark the spot welds drill all the ones you can see they should then prise apart then get the grinder out for the rest
<a href="VW Golf Mk1 Owners Club"> <img
http://i35.photobucket.com/albums/d189/vr6lad/forumsig_h.jpg
I used a normal drill bit and drilled all the way through, that way I was left with holes in the front lip of the car that I could weld through to fix the new panel.
My Build Thread
I was always advised to support the engine from the bottom, this way the weight if taken off the side panels. I think all the methods being used in this thread will work though
Looks like im going to be doing this in the next few weeks too
few questions!
the complete hadrians front panel, is it complete, as in crossmember etc, everything on the front of the car basically?
and is it a good fit? iv had some inner wing sections that left some to be desired and the outer wings were a shocking fit, from hadrians
once the spot welds are drilled out, where else is it jointed?
if i cut out the front of an inner wing at the same time, what will i go off to line the panels up properly?
Greg 8)
few questions!
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
u the man jamie………
its pi5s easy big powerfull drill and a bad ass grinder :mrgreen:
