Front panel removal.
(In Topic #88982)
Hyanes Restoration Manual for golfs is very good on the topic. :wink:
I have one or two ops: photos of the process
Mark
My cars -
72 Moonraker - http://www.volkszone.c…i/showthread.php?t=304603
MYSPACE
My cars -
http://dubforce.net/pi…files/webfiles/Rallye.htm72 Moonraker - http://www.volkszone.c…i/showthread.php?t=304603
MYSPACE
Took me 3 to 4 hours to get it off…
My Build Thread
What I did do though was to cut a piece of 2x4 the right length to wedge between the two chassis legs BEFORE I cut the crossmember out. The weight of the engine hanging on the two side mounts could pull the legs a bit… It was certainly wedged in a lot tighter once the member was cut out!
My Build Thread
<a href="VW Golf Mk1 Owners Club"> <img
http://i35.photobucket.com/albums/d189/vr6lad/forumsig_h.jpg
My Build Thread
few questions!
the complete hadrians front panel, is it complete, as in crossmember etc, everything on the front of the car basically?
and is it a good fit? iv had some inner wing sections that left some to be desired and the outer wings were a shocking fit, from hadrians
once the spot welds are drilled out, where else is it jointed?
if i cut out the front of an inner wing at the same time, what will i go off to line the panels up properly?
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
scotboy said
mark the spot welds drill all the ones you can see they should then prise apart then get the grinder out for the rest
u the man jamie………
its pi5s easy big powerfull drill and a bad ass grinder :mrgreen:
