electric roof not working
(In Topic #131142)
Also there is a adjustment tap type thing, should I try adjusting that or is the problem most likely that fluid is too low?
Thanks,
Matt
1986 mk1 gti cabby
sometimes it works fine other times its doesn't, if it doesn't work i hear a clicking in the boot which im told by a recent check over by a specialist sparky ! the clicking is the relays. 3 in the boot
the oil is topped up correctly so my next thing im going to do is replace the relay, he also mentioned that the motor might be sticking and give it a tap to see if that helps it along !
but all is good at the present
i have scanned in the pages from the manuel to show you all about the roof and topping oil up, hope it helps
keep us posted on any results
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
the thick red wire going to the fuse box was corrided at the fuse end !
it was attached and had power some times but not other times
so check your fuse bo! x it should be seperate to the main fuse box, it sits on the side and connects into it
jay
Jay
