Dropped sunroof anyone help?
(In Topic #144276)
Sunroof has dropped on back of panel, is this a easy fix or major job? Any help would be great as this is my first mk1 and I'm a novice.
Cheers,
Spill.
at the back you need to look sideways in the gap theres a bolt/screw which you loosen then you can adjust the height at the back, its a toothed bracket with a slotted hole if that makes sense
pics:
Google Sites: Sign-in
rubjonny said
do you just mean the metal panel is sat a bit low? if so simple fix. open roof half way, then pop the front of the inner trim off just pull it downwards there are a row of clips. then close the roof fully and push the inner trim back till you can see all the fixings that hold the panel to the slide mechanism.for the front you loosen the 2 outer cross head screws then adjust the large round disc with cross head to change the height, then tighten the 2 cross head screws again.
pics:
rubjonny. I have had a look at the pictures but is there a thread on removal, recon and replace for the sunroof? On a scale of 1 to 10, how hard is it?
then repair/replace roof panel as desired, change the seal, drop it back in and reattach the fixings.
dead simple
