Double light to single conversion, Help please!
(In Topic #80526)
Is yours a Clipper cabby?…cos I recently changed my double clipper grill to the single crome trim one and everything went fine. At first I thought it was going to be a hassle thinking that the full beam was simply in the inner lights, but it isn't and full-beam is still brilliant without the inner lights. This may be a bit unprofessional but I've simply got my inner bulbs etc taped up and safely out the way. You can put the single grill straight on, if its the finer single grill off a tintop like mine is don't over tighten the top screws as thats the only thing holding it on and you don't want to put them under stress etc. Hope that has helped, bit long winded…but basically you can put it straight on and be cruisin' in 20mins or less!! ;-)
Cheers Julia ;-)
MOT ??
Thanks again. Lee.
Julia
The outer headlights are the same as the single light cars and are all you need for your MOT…
My Build Thread
