Doors not shutting properly
(In Topic #111538)
When I open the window, they shut perfectly!!!
Is this a common fault problem with Tin Tops??????????
Tried adding washers in the hinge to line the door up better but that didn't work.
Also tried just giving the door a good hard yank upwards to align but still no luck.
I live with it.
Can anyone else help???
adambek said
hi, try the search section, theres quite a few old threads on the subject. the plastic wearing away on the door striker pin can be a problem.
Yep. That's usually the problem if the doors are lined up properly. Bit of heatshrink will do the trick.
1988 1.8 carb Golf Clipper
