Door Restoration
(In Topic #85662)
Door Restoration
I've been restoring my rusty front door and filling in any imprefections. During last week when it was a sunny warm day i sprayed the door with some 2k primer.
Its the first time i've done any spray work myself. Once i finished spraying i noticed afew runs in the primer, and afew tiny bubbles. Just wanted to know whats the best grit sandpaper to use, just before aplying the final coat and for getting rid of the runs in the primer?
Regards
vw_tees
Rub this down with p600 wet and dry , see the link below or buy Haynes body restoration and painting book [Ebay or Amazon allways have loads] . The preperation is the most important part .
The DIY Paint job
Cheers………..
Hey johntheboy, no im not from teesside. I've added around 4- 5 coats of primer, so hopefully I don?t get anymore tiny dots in places after sanding. I would have thought that any miner marks would be invisible after the top coat is applied?
vw_tees
Afraid not mate,you will see marks on the door through the topcoat once its gone hard so make sure you`v rubbed down all your filler/prep work correctly first then rub down the primer with 600 wet and dry as one of the lads already siad and you`ll be ready for topcoat :y:vw_tees said
Cheers "Chudd", Doing a guide coat makes sense that way i can hopefully get a flat smooth surface keyed ready for the top coat. Thanks for the link.
vw_tees
Hope that helps a bit mate
keep on keeping on
Timski: Yeah I know what you mean after spraying the bar I have noticed the areas which I didn't pay enough attention to during the sanding of the primer they have shown up in the top coat. Lucky the top of the bar which is visible I sanded down well which ending up looking ace.
Cero: Yeah I?ve got all the safety gear you defiantly need it with the amount of fumes it gives off.
vw_tees
johntheboy said
im guessing your from teesside from your name?
I've made that mistake before
I think he produces VW t-shirts….hence the Tee !
DubPartz
vw_tees said
The wet and dry sand paper did keep getting clogged every 2 minutes tho which was a bit annoying.
Might be daft question but did you use it wet? If not that'll be why :wink:
