Door Locks
(In Topic #114762)
Door Locks
If they are worn out can I get locks built to a key (like Ford locks) or will it mean a complete lock set or two different keys? :dontknow:
I would strip down the locks and clean up the tumblers,springs and barrel before lightly re-greasing them and re-installing. The tumblers will all be numbered so providing you replace them in the order they came out you should be okay.
DubPartz
Thanks for you help
GIB3000 said
Will try that
Thanks for you help
Put your key in the lock before you undo the retaining screw in the rear of the barrel, then withdraw key and barrel in one go. :wink:
Go easy and make sure you don't lose any of the tumbler springs and make a diagram of the order in which they load up.
All will become apparent once you start dismantling it.
DubPartz
GIB3000 said
spoke to crazy quiff today they will rebuild a lock to your key for ?15.00. Might be a good option for me!
So ?30 for two then 8O I'd opt for the DIY option.
It is really easy and you'll have the satisfaction of doing it yourself.
DubPartz
