Door hanging low
(In Topic #138348)
Door hanging low
I just wondered if anyone else has had this problem and could tell how they got it fixed.
Thankyou.
It was only rubbing the sill but enough to remove the paint work down to bare metal .
I think the pins are still available from any vw garage and they were on €9.00 each at the time
Jellybeans
Of course, it's no substitute for changing the pins, but if there's wear in the hinge itself rather than just the pins, it'll need boring out and a larger diameter pin fitted…
I've tried them all on my cabby and mk2 and the only way to sort it properly is to replace the lower pin. the washer trick at least wont bend anything so it'll be straight when you do replace the hinges!
