Door check strap prob
(In Topic #72352)
I've got a problem with my drivers door check strap. It is not attached inside the pillar (car side not door). It has been like this since i've had the car so don't know how its happened. Cant reach it from anywhere and my local body guy dosn't know what to do other than welding it in situ, which I'd rather not do. Have any of you seen this before? or know how to fix it?
Also, said door is a little droopy. I'm sure this has been discussed before but if you could point me to the right thread i'd appreciate it .
andy
Black MK1 GTI Campaign SOLD
Blue T5 GP 2010 Transporter (Van)
Orange M6L 2012 Brompton (Bike)
Neversummer 2012 Revolver (Snowboard)
As for droopy doors, they have bee discussed on the old forum.
My remedy is quick and easy though…
Take out the bolt that holds the TOP hinge together.
Place a washer (The thicker the washer, the more "lift" you get) between the two hinge parts and replace the bolt. As the part of the hinge that is attached to the door sits in FRONT of the part that is attached to the car, the back of the door is lifted upwards.
Have a look, you'll see what I mean.
AL.
My Build Thread
1996 Gti Anniversary 8v Mystic Blue
1995 Gti 16v Fjord blue
but as for that check strap, well … :?
This may sound rough but works and doesnt need that much force.
I fit industrial doors and this is done through out the industry too. 8O
Can you tell me how you get on with yours Andy and I'll then give mine a go.
'83 Helios Campaign Gti
not yet tackled that check strap, but will see if i can't do it soon, I mean its only been like that for nearly 2 years ops: .
But to Al_Mk1 , cheers mate that washer trick worked a treat. Well, after I realised I needed to move the latch pin also, as the door wouldn't shut!
MMmm… straight lines….
No worries! Glad it worked.
Must have been out by quite a bit if you needed to move the latch pin too though!
My Build Thread
yeah it did move up a bit, thats why i am pleased about the straight lines!!
By the looks of the paint, the latch pin had/has been moved down a bit in the past. :?
nice one Al, can recomend this tip to others. It only took a few minutes to do.
